polaris 2014 outlaw 50 wiring problem
Don't know if it has the same wiring as the earlier models,but should have a red,brown,black and green. If it's the same,the green should have power and goes to the tethered switch,from there should have power to the green/yellow wire at the left control start switch.If you're not jumping power from the switch could be the switch itself, switch harness connector or a wire may have broken loose from the solder from the back of the switch itself.We had problems with them doing that.
