Clutch cover
Old 10-03-2015, 12:35 AM
cornermike's Avatar
Default Clutch cover
Well winter is on its way and i plan on spending some time touching up a few things on a couple of my machines during the off season. Other than some cosmetic stuff like replacing some handle bar grips and painting some rims, I would like to replace the clutch cover on my 93 350L 4x4. The old fella that had it before me had a plow on it with a hand lift and he had it set so that he had to pull the handle so it pushed against the clutch cover before it would hold the plow up. This, of course, made a bad spot on the cover where it rubbed on the clutch. I adjusted the cover so it doesnt rub, but the cover is warped in this spot that it still contacts the clutch at times. What other model clutch covers fir this machine? I have tried to find used or new ones, but havent had much luck for this model. I am hoping someone here had the same issue and found a newer model cover that fits this style of machine.
Thanks,
Mike
Old 10-03-2015, 12:49 PM
What I used at the shop for the old 350 was an updated 400 cover #5433542. You may have one extra hole on the cover that's not on the backing plate,but it's no big deal and you can still use your air exhaust duct. Problem is trying to find a good used one. New ones are $150 on ebay,but you can get one here for a little over 100 bucks. http://www.cyclepartswarehouse.com/f...1994&fveh=5383
r1pilot83
Utility ATVs
15
11-25-2019 11:39 PM
wrencher82
09-30-2015 04:27 AM
tysonbully
09-28-2015 02:30 AM
Ricardo Covarrubias
09-17-2015 08:28 AM
Lou Domenech
09-11-2015 06:35 PM
Quick Reply: Clutch cover
