strange problem
That's what you're supposed to do if you torque the nut to 14 foot pounds and the cotter pin doesn't line up. Just back off the nut until it does. Ohm out the gray and brown wire for the awd coil on this side. Should show a resistance of around 25 ohms or so. If it ohms out ok,power is going to the gray wire,then yes tear it back down and inspect the face of the coil sleeve and the inner strut pole. These are the two places the armature plate rides against. If either are damaged/ground down or out of alignment with each other,the armature may not get a good magnetic pull.
#16
#20
Seems every year the manuals say a little different on hub nut torque. Some manuals show a variance with 144 inch pounds(12ft pounds) being max. Later models show a first stage torque of 165 inch pounds(around 14 ft pounds) then a second stage torque of 124 inch pounds(10 ft pounds). I said to heck with it and did it my way. I always just preloaded the bearings to 15 foot pounds,backed off 1/2 turn and split the difference between 165 and 124 inch pounds. Around 12 ft pounds.
