Changing gas tank, need help
Old 03-26-2016, 03:15 PM
Originally Posted by Yekrats
And what's the trick to getting the old fittings out of the damn fuel lines?
Might as well cut the fuel line below the fittings as you'd mangle the fuel line up getting them out. Plus you should have plenty of slack on the lines.Again use a little dab of grease or wd40 on the inside of the fuel line when inserting it into the new fitting. Makes life so much easier..
Old 03-26-2016, 04:17 PM
Yekrats's Avatar
Okay, looks like I'll need to go shopping for more of the washer/gaskets before moving on
Old 03-26-2016, 05:49 PM
Not getting your drift on this? If the tank has the grommets and fittings installed(washers as you call em) all you have to do is snip the fuel lines below the old fittings,lube the fuel lines and slip them on the tank fittings,then slide the clamps up.
Old 05-18-2016, 08:37 AM
Yekrats's Avatar
Tank is back on. Followed the suggestion to cut off from the fittings, and they didn't quite leave enough hose. I'm not able to get the line on the tank fitting all the way without creasing it. I thought I'd go ahead and buy new lines, but it appears the 8450103-600 is obsolete. I assume it's been replaced by another number (probably the same part from another atv) but I haven't figured it out yet.
  #15
Old 05-18-2016, 02:30 PM
Just match up the fuel line at your local auto store. If you want oem,then you'd pay top dollar. Here's what the new part is.Just bulk fuel line. http://www.partzilla.com/parts/detai...FYsCaQodAxcLgw
Bernhard
10-23-2015 11:33 PM
loco moto
Technical and How-To Articles
10-19-2015 08:14 AM
exmotocrosser
09-26-2015 08:18 AM
Sw00p
09-24-2015 02:50 PM
Quick Reply: Changing gas tank, need help
