Wider Then Stock Wheels and Tires In Front
Has anyone ran larger then stock wheels and tires on the front of a 2007 Sportsman 500 or similar with or without spacers? Don't want tracks but do want flotation in deep snow. Would like to run 26-12-12 or similar all around. Any sand tires and wheels especially made with this bolt pattern for this quad or has anyone came up with a combo that works good? What was the steering like?
Thanks for your response.
I have an 06 800 and I had 26 10 12 on front and rubbed on tie rod end, I added on each lug a flat washer than 2 of the thickest lock washers then another flat washer and had enough threads for safety. I also ran at 7psi. I doubt u will get the 12s not to rub without a proper spacer.
Did you go up in wheel width or just put a larger tire on the stock front rim. I might see what I need to do to use the rear wheel and tire size in front just when there is powder snow and switch back when it gets icy.
Had to use a 10 width tire up front, I wanted 9" on all 4 but the tires are only 10 and 12 wide.
Joesn68
29
02-03-2019 11:24 AM
Matthew-Becca Morgan
11-09-2015 06:32 PM
