Clutch thoughts 550xp
I had a package last week that was priority 2-day shipping and it took a week to get here. I think they misplaced it for a few days. Hopefully yours gets there when it's due and you can tell us how it works out.
So I rec'd the EPT Silver spring today. 20 bucks from amazon. It did in fact drop the engagement RPM from a previous engagement RPM of 2500 to approx 2200 on my 2010 550xp. The whiplash effect from the harsh engagement was reduced but not eliminated....I would consider it harsh before the swap...now, after the swap, only a sharp engagement...but the engine is torquey so its not gonna be mellow unless you managed to drop it into the teens to engage.
The swap time, well I cannot accurately tell you the exact time as I greased the rear end during the job. Also I took my time doing it. I can say that you will have to partially drop the rear skid plate...simply remove the bolts at the rear most point by the hitch and the bolts at the mid point in the rear wheel well. (2 ) at the rear, 2 at the mid point. no need to remove the whole skid plate by removing the 3 under the quad. There are bolts for the clutch cover that require lowering the skid plate to gain access to them.
If one focused strictly on the spring swap I would guess under 2 hours to complete it. But it would be silly to not grease it up while the wheels were off. I did remove both rear wheel to gain access to all the cover bolts. Also the seat was removed.
Was it worth the effort?
I would say yes...for 20 bucks and a few hours of barn time...yeah, much less expensive than a clutch kit that might not have addressed the exact issue. but i will ride it more and update this thread as req'd.... but it does not want to yank me off the quad or snap my neck when I take off on it with the short amount of time i have ridden it since the swap.
#15
Glad it helped at least a little for you. This can hopefully help other 550 owners.I remember the first 550 and 850s we got in at the shop and the higher idle speeds and harsh clutch engagement compared to previous models. The 550 does have a lot of torque though and guess that's part of it.
#17
Blueoval78
1) Engine problems..
01-26-2016 09:01 PM
SOLOLUCKY
01-25-2016 08:02 AM
