Polaris trailblazer 250 stuck at full throttle
Its not a factory hole. Looks like someone ran it into a tree or a rock. I can see the start or motor gear when I look into it. I'll do the best test I can tomorrow to see if I have a leak but it might not be for a few days some bad weather is coming my way and I don't have a garage to work in. Thanks for all the help I would have no idea what to do by myself. Once I do the test I'll post what I find.
#15
I did manage to work on it a little today and found out that the hole is not the problem. When it was idling I sprayed some carb cleaner in there and the revs did not change. I did find one leak in the carb boot. I ordered that part aftermarket along with a gasket set and the directions were wrong. It told me to put it on the intake boot from the airborne but when I was looking at some diagrams today I found out that goes on the carb boot. Sure enough when I turned on the quad and sprayed some carb cleaner on there it revved up. I put the o ring on correctly and that problem stopped. I found another air leak in one of the studs that connects the cylinder to the crank case; how would I fix this leak?
#16
#17
I ended up taking apart the whole engine again and found out that some of the old crank gasket was not removed all the way which would explain the air leak. I pealed all that off and used some high temp RTV to help completely seal it up. I put everything back on and now it won't even idle anymore. I also noticed that when I give it has to try and start it some of the fuel mixture stools back out of the carb when it is bogging down. Is this normal for 2 strokes? I also did find out that the electric start works, this project will really speed up now that I do t have to pull start it every time.
#18
#19
#20
The engine has already been rebored and has a brand new weisco piston and new head and crank gaskets. The compression reader I have is has a leak so it reads every engine bad but I used it anyway and even with a leaky tester it read 65psi. There is no way the compression is bad.
