Jacking up Sportsman & jack stands?
Getting new rubber come spring, keeping the OEM wheels. I will need to jack it up to take the wheels & tires to be mounted. This will be the first time I have ever had all four off at once, How can I jack it up and support it?
I have 4 jack stands...thoughts?
Like 1ArmBandit said use the jack stands.. Just jack the front up enough to have the tires off the ground,place two jack stands behind each front a-arm,lower it down,jack up the rear,place two in front of the rear a-arms clearing the tires. Plus this way you can easily check for any wear points on the suspension tie rod ends, wheel bearing play,ball joints,prop shaft u-joints and drive shafts and boots while it's off the ground.
