2006 Polaris Sportsman 500 EFI sputtering and battery icon flashing
Good point.. Entirely possible a faulty charge coil in the stator could be the problem since the pdm has been replaced,but that's where the manual comes in to play. Cheaper to spend the 5 bucks for the manual,go through the stator tests and resistance specs to be sure before you throw good money on a new stator that may not solve the problem.That's why I keep pushing manuals rather than have people throw parts at machines.
Coil
When running and sputtering. Mine did the same so I changed coil and plug cap with a cap with a resistor and rubber boot and it came out of it
#16
Like the old saying a picture is worth a thousand words.. Plus is the flywheel key sheared on the crank shaft or the shaft messed up any? Kinda hard to see on the picture.Plus there's some cheap aftermarket ones now for a fraction of oem prices.http://www.ebay.com/itm/Stator-Polar...RVr4-v&vxp=mtr That is unless you don't mind spending 575 bucks for an oem stator. Plus I'd still have the battery load tested also. Depending on how long this is been going on a battery can be sucked down enough and can cause problems on being able to hold a charge if it has an open cell.
#18
#20
Then I guess just chalk it up to a fluke failure even if it says Japan on the pick up coil.Even Ktm used Kokusan in a lot of bikes and we hardly ever had a problem on them,but this just shows that nothing's invincible
