water pump - looks to be leaking from seal, maybe not weep hole
Nope don't make things worse.. Here's some good pics on changing w/p seal on a Rzr 800. Same principle on the 700. Once you get the flywheel,stator and case side off,seals aren't that bad to remove and install.You could unplug the stator and leave it on the case,but it could get damaged that way.Didn't like that way he did that. Step by Step - How to Replace the Water/Oil Pump Seal - Polaris RZR Forum - RZR Forums.net If the shaft needs to be replace,the double spring loaded cam sprocket had to be removed,4 allen bolts holding the oil pump removed and the pump can be lifted out to be taken apart. Dots have to be aligned back up on the gears upon reassembly.
Just "borrow" a good harmonic balancer puller from any good auto supply for just a small deposit. Some are tough to remove and you have to be careful not to damage/mushroom the crankshaft end. A little heat from a propane torch around the tapered shaft can also help. If possible,thread the nut on a couple threads so if it does flare the nut when removed can straighten the threads out. Here's the best video I've found on pulling the 700 flywheel.This video was about changing out the Ducati ignition for the updated Kokusan which hopefully you already have.
#15
Just "borrow" a good harmonic balancer puller from any good auto supply for just a small deposit. Some are tough to remove and you have to be careful not to damage/mushroom the crankshaft end. A little heat from a propane torch around the tapered shaft can also help. If possible,thread the nut on a couple threads so if it does flare the nut when removed can straighten the threads out. Here's the best video I've found on pulling the 700 flywheel.This video was about changing out the Ducati ignition for the updated Kokusan which hopefully you already have.Polaris ignition upgrade and flywheel removal - YouTube
the manual says you are supposed to replace the 2 bolts that are behind that stator because they have some stuff on the end so no oil leaks in. I went to a polaris shop but they said they dont carry those bolts, the mechanic there reuses them. The mechanic was not there to tell me what type of sealant to put on the end of these bolts, any suggestions?
#16
#17
Long thread without mentioning what ATV it is. If its a 500,455,425 here is the screw trick that comes in handy. Untitled Page
#18
sealing the crankcase halves back togethor the manual says: Apply Crankcase Sealant (PN 2871557) to the outside
edges of the crankcase halves (See arrows), where the
crankcases mate. (See photos below.) This helps to prevent
coolant leakage.
Did you just apply to those 2 little spots or do you reccomend i coat the whole thing?
#19
I've always been of the notion that if a little dab would help,then a whole lot would help even better.. Doesn't always work that way,sometimes too much is just that,too much,but not in this instance. I used a THIN film of Threebond 1104 all the way around the case. I even used a thin film of Threebond to hold gaskets in place.
#20
