2013 Sportsman 90 no electric start
At least it's getting power to the starter relay. You can check with a voltmeter or test light to see if the starter wire is getting power. If not,the the usual cause is a faulty relay. Item #13 on the parts break down.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse If the starter is getting power then it could be faulty.New Starter Polaris ATV Outlaw 90 and Sportsman 90 Replaces 0453478 and 0454952 | eBay http://www.ebay.com/itm/NEW-07-16-PO...5XMN~y&vxp=mtr
It's a relay(located under the seat) not a solenoid with two posts that you can jump across like other machines. Just use some jumper cables,ground neg to the frame and touch the starter hot wire if you wish to check it out that way. You still should be able to use a test light or meter first to see if power is getting to the starter motor from the relay when you push the start button and it clicks.
