The ol' polaris 500 cam/carb issue.
#21
#22
SO after the weekend. Good news, bad news.
Good: It is indeed the carb causing issues as it ran perfectly (Other than not idling) for well over 70 miles this weekend in some pretty rugged terrain. Couple high water crossings, lots of mud and plenty of hills. The choke was out pretty much the whole time, and on the plus side, since it idles high that way, it was like cruise control for trail riding. Kept me at a perfect slow and steady pace with a free hand for the coffee cup.
Bad: It still has a carb issue. But my carb rebuild kit came in today so I will tear into that this week. But I discovered another problem this weekend. It started overheating about halfway through the weekend. Couldn't figure out why. I started noticing my fan wasn't kicking on, so I thought with the high water crossings it shorted out my fan with some shoddy wiring connection somewhere. However, the issue progressed and I started to notice my starter was not cranking like it used to. Figured out the battery was dying and it wasn't getting charged. Pull start got me through the rest of the weekend and had to take it super easy or go really fast so as to not overheat. Home and I checked the volts and indeed when running it didn't move from 12.6. Found the regulator (thanks to this forum) and found it had come disconnected with all the jostling. Hooked it up and now it charges however it is over charging allowing voltages like 16-17. Is this likely a bad regulator? Battery seems to be in good shape as it holds a charge.
Also when rebuilding the carb, if the mixture screw completely strips out, can I use a left hand bit on it? I seem to remember I have a pretty tiny one. Or otherwise drill it out?
Also heres a photo of the weekends riding area. Love Alaska.
#23
Regulator wiring connectors were bad on the Sportsman 500 on pulling out,but 16-17 volts is too much.. You might run it a little while and see if voltage happens to drop down to the normal 14-14.5 volts that it should be,but if it doesn't order a new regulator. Be careful in messing with the fuel screw. If you have a small enough eze out or left hand drill you can probably get the screw out. Just don't go too deep and damage the small hole. Kit comes with the new screw,spring,washer and o-ring. Make sure to get the old ones out with a small pick and set the screw at 2.5 turns out from a lightly seated position and see how it does. Pretty riding area..
#24
As always, advice from this forum is always the best. Thank you again!
#26
#27
No need to post twice in the same section on the same problem.. Just confuses people jumping from post to post.
amalota
02-05-2016 01:45 PM
Peeps
03-24-2000 12:27 AM
