Polaris 570 Bighorns install
5 psi is what I run on just about any tire I have ever used. Good combination of ride and traction at that setting. I'm 205 lbs myself. Most tires are fine down to about 2 psi without coming off the rim. If you're a bit heavier rider, 5 psi should still be more than sufficient. The only issue in that case would probably be trying to go too low like the 2 psi lower limit. A few extra lbs of rider or gear would probably result in the tire popping off at extremely low pressures. At 5 psi, all should be fine.
CALL911
12
10-19-2016 03:18 PM
