Winch install mistake
I am installing a winch on a 2012 500 HO. I had to modify the mount to get it in because the negative terminal on the winch would not fit as it hit the bar on the front of the bike. I ground down the terminal after I attached the negative prewiring. Here is the problem, I realised after I did it that the negative prewire was suppose to go to the negative post on the winch solenoid. so mine goes from the negative post on the winch, to the negative terminal on the battery. Is this OK? I do not want to take the nut off for fear that i screwed up the threads on the post and won't be able to get back on.
No it will not work. The winch will only spin in one direction not both.
The contactor is a super high amperage polarity reversing DC switch.
It either passes the power straight through to spin the motor forward or reverses the polarity to spin the motor in the opposite direction.
I cut the wires and crimped ring lugs onto the ends of the wires sized to run to the contactor.
Nut may straighten out the threads as you remove it,enough so that you can get it back on.If not you may have to use the correct die and reform the threads which would involve removing the winch. Worst case is an insulated alligator clamp that I've seen some redneckers use that were too lazy to do it right..
Here is links to a service manual which includes a wiring diagram.
https://drive.google.com/file/d/0B_d...w?usp=drivesdk
