2003 polaris magnum 330 cranking
Hello friends i have this 03 pol magy 330 its extremly hard to start with the starter , when i warm it up it seems to start much better.. if i pull ut by the pull cable it almost starts immediately? Even during a cold start. What causes this? Suggestions???
Spam wordSpam word Spam wordSpam word Spam wordSpam word Spam wordSpam word signed .. Torn Rotator Cuff Guy
Battery in good shape? 325/330 engines were cold blooded to begin with,but if the choke is working ok but still hard to electric start,could be the pick up coil is getting weak or too far away from the strip on the the flywheel. Pick coil white wire to white/red should be around 97 ohms resistance. Distance on the pick up coil gap should be between .016 -.030 clearance according to the manual. May be similar to what happened to this poster on a Sportsman 500. no spark to plug when using electric starter - Page 3 - ATVConnection.com ATV Enthusiast Community
Check the distance with a feeler gauge between the face of the pick up coil and the raised portion on the flywheel which is the interrupter strip. If the distance is too far you'd have a weak spark sometimes using the electric start,but can pull start it because you can make it spin over faster which can allow a better spark. Read over this guys findings again..no spark to plug when using electric starter - Page 3 - ATVConnection.com ATV Enthusiast Community
