Polaris Oil
There's an endless supply of oils to chose from. From dedicated factory oil to dozens of brands of oils. Even diesel oils such as Rotella T6 5w40 is ok in most Polaris machines because of no friction modifiers and Jaso rated same as the expensive atv and cyle oils.Plus with most of the Polaris machines having a cvt clutch system,there is an even more good selection of oils that you can use.https://www.google.com/search?q=atv+...yjBDIQ_AUICCgD
I use the Rotella Triple T 15w40 is everything I own (including my Yamaha Vmax 1200 street bike)...it is a "diesel' variant in that it contains higher levels of zinc then most regular blends. The added zinc turns into a protective glass film under heat & pressure...basically it's a last defense for viscosity break-down. There are few negatives to the zinc content in these oils and often help stave off aluminum oxidation.
The T6 mentioned above is the more expensive synthetic version...both are excellent...
I tend to change my oil often so the "dino" stuff works for me...much cheaper to change oil than to rebuild motors...
Send a sample to Blackstone Labs. I was surprised that my Arctics does even better with Rosella than ATV oil or Mobil 1. First test was dedicated ATV oil, 2nd one was Mobil 1 Euro Formula, most recent one was Rosella T6. This model cat has the transmission share the same oil with the motor. Also use a K&N air filter.
Yeah OPT I live right in the city. I drank enough polluted water that I have lead in my blood now. The water never looked cloudy or had any taste other than chlorine sometimes. I didn't know there was anything wrong with it. It would be interesting to have an in depth check like they did on Hydrex's oil.
