06 Polaris hawkeye no spark
#21
Newer dci systems like yours have to have the battery for constant power to the regulator,etc. Older magneto triggered ignitions could crank up on a weak or dead battery with a recoil or kick starter. If a regulator went out on these they either just fried batteries from too much voltage or drained them down if they didn't put out enough.They didn't cause problems with modules as much as the newer ignition systems do.
#22
#23
#24
im reading blue/white to battery - and only seeing 12.4vdc - 11.2vdc in that ball park during cranking from the cdi. got ahold of tech support from the cdi vendor and they said you should see 2-4 volts from trigger. (did not spec if that was ac or dc but assume it is dc) sense I don't have the peak adaptor I cant do that test but i figure its one or the other on the voltage test when checking the pulse trigger. so asking the vendor if i can series a few AA battery's together to get give the cdi box a pulse trigger for testing there output.
#26
#27
#28
#30
Did you ever pull the black wire from the cdi to isolate it from the ignition and left control switches or have a good battery instead of the jetski battery?If you have and still no spark,then could be the aftermarket regulator or the after market stator and pickup coil. Beginning to have no faith in any of these after market parts. Polaris oem stators,cdis,and regulators are ridiculously expensive for this Korean made Hawkeye,but beginning to think that's the only way to go to keep people from chasing their tails.
