Can you use super glue on grips - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 04-28-2000, 12:33 PM
Well I am getting ready to put some soft grips on the Polaris, has anybody tried to use super glue or knows if this will work, has anyone ever heard of using the 3M weatherstripping for adhesion...thanks
Old 04-28-2000, 12:37 PM
i would just go spend 3 bucks on some grip glue and do it right.
Old 04-28-2000, 01:52 PM
jim jim is offline
I've used the grip glue twice w/ soft Oury grips & it worked great in dry & semi wet conditions but after riding hard in exreamly wet/muddy/thunderstorm conditions the grips worked themselfs loose. The glue dried hard & was not sticky. I now tried double sided tape 8 thick on the end w/ a plastic wire tie towards the middle/end of the grip so I'll see if this hold up.
Jim
Old 04-28-2000, 02:09 PM
I use silicone to hold them on. Cheap, available and pretty darn tough. I always seem to have a tube of bathtub or automotive silicone lying around.
DJ
Old 04-28-2000, 07:10 PM
Thats the reason I ask this question steve it wasn't a matter of money I just had some friends that didn't have good luck either with the grip glue...thanks for the silicon idea deej I think that is the route I will take.
Old 04-28-2000, 09:09 PM
I've personaly tried three different types of grip glue and they all come lose after a day or two of riding. Somebody figure this out and let us all know. Bye the way super glue don't work either or crazy glue, tried them also.
Later, bodineus
P.S- Maybe we all need to let up on the death grip...LOL
Old 04-28-2000, 10:33 PM
I have raced motocross and ridden 4 wheelers for 15 years now. There is nothing on the market that can beat using gasoline to secure your grips to the bars. Clean the surface of the bar to bare metal if you have bars that are painted, then swab some gas on the bar and the inside of the grip at almost the same time, you must work very fast as the gas will evaporate and at the same time weld the grip to the bar. When I say fast I mean just seconds from the time you put the gas on the grip to the time you start pushing it on. I found it works better if you have someone hold the other side of the bars so you have more leverage to push. Using this method your grips will never come off, slide around or even budge a little until you cut them off. Good luck
Old 04-28-2000, 10:59 PM
I've used the auto weatherstrip glue and it works great. My dealer recommended it. Cheap to.
Old 04-28-2000, 11:38 PM
hooven i will try that when i get my new bars in
Old 04-28-2000, 11:52 PM
I use my wifes sticky old hair spray. Dries pretty fast and is really sticky too. Also very cheap. The gasoline trick sounds good too. Also very cheap!
Thread Thread Starter Forum Replies Last Post
Stressing out help XxS0ccerstarxX Honda 2 09-22-2015 03:40 PM
ATV donut fail! black_thunder ATV Videos 0 09-07-2015 02:24 AM
Slagpolaris Slagpolaris Introduce Yourself 5 09-05-2015 10:41 PM
Polaris Sportsman 335 low top speed Steeldon Utility ATVs 0 09-05-2015 10:38 PM
super grip erntee61 Drivetrain, Suspension & Tires 5 08-09-2015 03:54 PM
Tags
atv , buying , crazy , glue , glueing , gluing , goop , grip , grips , installing , kind , motorcycle , oury , pro , super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
