How to overide reverse button 2012 Sportsman
Old 12-08-2016, 03:53 PM
bmm32005's Avatar
Default How to overide reverse button 2012 Sportsman
Plow season is almost here and I want to override the reverse button. Can someone steer me in to procedure to do this? I have a 2012 Sportsman 500HO. Thanks
Old 12-08-2016, 04:13 PM
This is from someone else.
"Reverse override mod"
Polaris has incorporated a safety feature on all their 4wd models. This feature, which is operational all the time when reverse is selected, will limited engine power and cut out the front wheel drive unless you push the “override” button.
One of the main reasons you would want to do this mod is because when you get stuck and the only way out is reverse, it is impossible to pull the ATV backwards while applying throttle AND pushing the override button. It is also very helpful when you use your ATV to plow and need 4wd every time you back up with the weight of the plow hanging off the front.
This mod will give you 4wd and full power when in reverse without having to push the override button. This is for all Polaris Sportsman models with the new style Speedo (2003) and Sp700, 02. Continue down below for pre 03 model instructions.
The problem with the new style, is that the function button for the Speedo is combined with the override button and it is not as straight forward as the old style Speedo. Doing it this way everything works as it should exactly the way it did before the mod.
The nicest thing about this mod is that you do not need to cut any wires or drill any holes.
You will need to purchase a standard 4 pin, 12v relay, 4 pieces of 16 gauge wire about 8″ long, 4 female crimp on spade connectors (for connection of wires to relay), and 4 wire splice connectors. (they are usually blue and you simply insert the wires and squeeze with pliers, then fold back the protective locking cover)
Open the pod and locate the wiring harness coming from the Speedo.
Relay terminal #30 connect to Polaris brown wire
Relay terminal #87 connect to Polaris wire gray/orange
Relay terminal #86 connect to Polaris wire red/white
Relay terminal #85 connect to Polaris wire purple.
Use dielectric grease at all electrical connections to prevent corrosion in the long run or even better, liquid tape.
To test, simply put it in reverse with the engine running, if the Speedo flashes the word “SLOW” (just like it did before the mod, when you pressed the override button) you did everything correct.
Plus here's a post on this from Polaris atv forum.NEW REVERSE OVERRIDE & REVERSE LIGHT MOD!!! no switches and working scroll feature! - Polaris ATV Forum Plus don't know if Quadovator is still into this but here's their website.ATV Accessory
