Polaris Ask an Expert! In fond memory of Old Polaris Tech.An area where experts in their field will answer non-general questions about your Polaris ATV. "old polaris tech" and other experts will answer your questions as they have time.
ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE POLARIS FORUM. Basic or General questions posted in a expert section will be moved!
Recently i had to replace the belt and after that it was fine for the first 5min or so now every once in a while it sounds like something is rattling around in the transmission
Did you remove the rear clutch to install the belt? If so the the bolt may have rattled loose.Even if you didn't and just rolled the new belt over the clutches, I'd pull the clutch cover and check it out.
