Predator no compression
Old 02-21-2017, 03:09 PM
Harry Clevenger's Avatar
Default Predator no compression
I have a 03 predator and i bought it knowing it didnt run. I found out it had no compression so I tore it apart and found that the piston seamed a little loose in cylender but other than that head looked fine and cylender was not scored. I even turned head upside down and filled it with gasoline and it took quite a while just fo a litfle to leak out. I know this engine has the camshaft with the compresion release but i dont k ow how to check if something is wrong with it. What would you do at this point.
Old 02-21-2017, 03:13 PM
Get this manual before you go any further.It will show what you need to do on valves, piston,etc.2003 Polaris Predator 500 Service Manual PDF Download
Old 02-21-2017, 03:17 PM
I have the manual and haveven looked through it a lot. I just don't know if maybe the piston rings are worn out to much, the valves are leaking, the compression release cam is releasing all of the compression or a combination of those. I just was wondering what I should do next so I do think waste any money
Old 02-21-2017, 03:26 PM
Read the manual on the piston to cylinder clearances,ring end gap,etc.. Along with the trouble shooting guides.
Old 02-21-2017, 03:43 PM
Ok will do
