Weak spark no start
Old 02-22-2017, 05:02 PM
Jswarrior's Avatar
Default Weak spark no start
Ok guys new to the forum ...just throwing that out there for whatever reason. So I have 99 warrior fresh top end all new gaskets new coil boot fully rebuilt carb etc ...the bike was running good and it just stalled and will not restart. I did check coil ohms out at 13 ohms( don't know stock ) also did check compression and from I see online its good,the Orange signal wire only has like .23 cold coming from it....any help would be awesome.
Old 02-22-2017, 09:47 PM
Jswarrior's Avatar
Meant to say .23 volts coming from the signal wire
Old 02-24-2017, 02:59 AM
Not sure, don't go much on resistance and voltage readings. I think .2v is enough, 0.7v is Honda's specification. Have you tried checking for a spark? Have you changed the plug? Have you checked for a voltage (Fairly high AC) from CDI to coil?
Old 02-24-2017, 05:37 AM
Jswarrior's Avatar
Yes I have some spark and it will try to start if hold your hand over the carb. It ran good for about an hour after doing all the work on it.
Old 02-25-2017, 11:38 AM
Clean the carb out again, you may have got some more dirt or water through from the tank. Compression of over 90psi is good enough for the engine to start OK.
Old 02-25-2017, 04:44 PM
Jswarrior's Avatar
I have gone through the carb and its all new I did a complete rebuild on it.
Old 02-26-2017, 05:00 PM
Jswarrior's Avatar
My compression is sitting at 120 all day long
