How often do the temp switches that run the fan go out?
on
2001 Polaris Sportsman 500
Do they ever fail while still showing 12 volts at the fan plug?
Mine has 12 volts at the fan plug as soon as the key is turned to run.
I have yet to check to see if it is delivering enough juice to run the fan.
I have had similar switches fail and still show they are delivering voltage. But not enough amps to run the item they were intended to power.
I will be installing a relay that will be triggered by the fan switch to run the fan. In hopes that this will extend the life of the fan switch.
Is it the load of the fan that kills the fan switch in the radiator?
Thanks
Thanks
Radiator sensors failed often. One side may show power,but the switch can be burnt inside and not able to trasnfer either power or ground signal to trigger the fan motor.Plenty of cheap 26 buck sensors on ebay.COOLING RADIATOR THERMAL SWITCH SENSOR Fits POLARIS SPORTSMAN 500 4x4 2000-2003
on
Mine has power coming out of the switch to the fan.
I was curious as to whether these switches failed closed. From what I have read most of them fail open - or maybe nobody checked for voltage and just installed another switch and ran.
When I finally get outside, I will connect the fan and see if it runs.
Then I will install the relay.
What size inline fuse should I use on the relay I will install and toggle switch that the previous owner installed to run the fan?
The circuit breaker is 10 amp. Do I need to go with slightly bigger fuses?
I am assuming the circuit breaker is the auto resetting kind. Is that correct?
I am going to leave the toggle switch in place since it's already there. But I am definitely going to install a fuse in front of it.
When I install the relay to run the fan the existing fuse / circuit breaker will not be under the load. The load will be from the relay
on
Since I will be installing my own circuit with the relay I will need to install a separate protection system.
I guess I will start with a 10 or 12.5 amp inline fuse - if that blows, I will go heavier.
I will leave the OEM circuit breaks as is to trigger the relay and set back to stock easily
