lonestar a-arms
lonestar a-arms
I would get a cheaper set of a arms such as armadillo, wicked, ect. since they are just as beefy, and don't require you to spend excess money on offset rims or other various parts such as ball joints. You can then use the money you saved to go all out on suspension. I can't tell you how much I recommend axis, elka, pep, tcs, or ohlins over the works, they are by far superior over them. If you buy the suspension just save a few months longer, you'll be many more times satisfied with the mentioned brands over the works. I have the armadillo a arms, and they've taken all sorts of beatings on boulders, ect without getting any dings once so ever (they are very thick chrome moly steel, and well powdercoated too).
lonestar a-arms
The money you can save from NOT buying the lonestars and rather buying one of the cheaper a arm sets will give you enough to pick up some of the simpler sets of the good brands of shocks. Lonestar is just overpriced for us rec riders, I'm just trying to help you get the bigger bang for the buck. Just figure you can save 2 to 300 on a different set of a arms, and if you just saved about 1 to 200 more you could end up with dual rate elkas or similar.
