Sport Quads Discussions on sport quads.
CYLINDER NOT FIRING
Old 10-29-2004, 12:04 PM
treylaxbanshee's Avatar
Default CYLINDER NOT FIRING
Just so you know I have not checked anything yet, I only have one cylinder that sees to be firing at idle or low speeds but at full throttle or any other time that I just get on it, it will run smoothly. I have put new plugs in but i have not beenable to test due to a oil plug problem but just lokng for recmmendatins if the plugs dont work i will take a compression test and then start tearing things apart
Old 10-30-2004, 12:27 AM
blindside350's Avatar
my bet is that you have the rings are broken; but as you run a higher speeds the engine is hotter so the rings expand letting it compress... thats what happend to us atleast...time for a new top end
ultangler
09-05-2021 08:06 PM
Dewhound
04-20-2017 02:25 PM
mrtidy
02-03-2016 05:00 PM
IMLN
09-28-2015 03:32 PM
Elkaholic
09-06-2015 02:44 PM
Quick Reply: CYLINDER NOT FIRING
