Sport Quads Discussions on sport quads.
carb overflow tube??
Old 12-14-2004, 10:31 AM
free2ride1's Avatar
Default carb overflow tube??
i have a dvx 400... and i dont think i have a carb overflow tube??... just to see if it came out of that tube coming out of the bottom of the carb, I tipped it on the side... and nothing leaked out?? does it have some kind of fuel return if the carb gets too full?... not to mechanical inclinde.. need some help
Old 12-14-2004, 10:54 AM
Trevor's Avatar
My 300ex will pour out the overflow when i do wheeles but not on it's side!
Old 12-14-2004, 04:25 PM
hondabuster's Avatar
Sould have one, but it could be plugged.and Rolling on the side may not cause the gas to overflo out the tube. If you loosen the screw at the bottom of the float bowl does gas come out of the tube? If it does, then the line , outside the carb,isnt blocked.
If you want to make sure, drop the float bowl and check to see if its plugged.
On my photo page is a picture of a float bowl, and the brass tube sticking up, is the vent/overflow tube.
Old 12-15-2004, 03:07 PM
free2ride1's Avatar
hondabuster, do i have to drain the gas out of my tank to drop the float bowl,on my 416ex, if you tip it on its side, it leaks out gas?
Old 12-15-2004, 03:53 PM
Its normal for gas to leak out the overflow tube, when a quad is on its side. But its not a sign, that someting is wrong, if it doesnt.
Shut off the flow of gas to the carb, then unscrew, a few turns, the screw on the bottom of the carb, to drain the float bowl. Then you can take off the float bowl without splashing too much gas around.
Theres no fuel return, the float needle and seat, shuts the flow of gas, when the float rises. This is supposed to prevent overflowing, but if the needle sticks, then the overflow prevents engine damage by providing a way for the excess gas to escape.
Im not sure you have a problem...what other symptoms or problems does it have...or are you just curious?
Heres a good site with info on carbs.
carb
carb 101
Old 12-15-2004, 04:45 PM
free2ride1's Avatar
I'm just curious really.... i just have never seen any gas leaking out of the overflow, and i have owned it since it was brand new. Its about 3 months old. i have even tipped it back on the wheelie bar and nstill, nothing leaks.
Old 12-16-2004, 06:41 PM
86LT250RFatty's Avatar
If it runs right i would leave it alone.
Old 12-17-2004, 12:45 PM
free2ride1's Avatar
i just got released from my surgery yesterday, and i rode her for only an hour (really cold) and it ran great... i think i might leave it alone.
Thanks for all the info guys
Nate
GregM
03-06-2018 06:53 AM
TLC
07-25-2015 02:24 AM
southbayman
07-24-2015 09:30 AM
Aitch
07-21-2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Quick Reply: carb overflow tube??
