Help!! 1995 warrior wont start
Very gently tap the starter motor with a 3/8's drive rachet while pressing the starter button. Do not hit it hard, just a tap because if you "slam" it, you can actually break the magnets. So if you tap on it and the starter turns over, the starter has worn/dirty brushes. The most effective way to T/S this is to measure the voltage at the starter when the "start" button is pressed....should be around 12vdc. And ensure you have a fully charge...good condtion battery.
