LT500 cooling probs
Old 09-05-1999, 09:40 PM
roostmonkey's Avatar
I have a 89 500 Quadracer that has a cooling problem. While running the cylinder gets hot but the hoses and radiator don't.
While running I pulled off the return hose(head to top of radiator) and water was just dribbling out.
I ran water through the system via a garden hose and the water was coming out good.
I pulled off the side case and inspected the waterpump. The impeller looked perfect and doesn't spin w/o the motor turning over.
So what do you guys think is the problem?...air in the system and the impeller is cavitating?..any ideas on a fix?...Could it be the radiator cap?
The bike has seized before because of this problem and it is getting expensive to fix.
Thanks
Brian
By the way, I love this new UBB
Old 09-07-1999, 05:53 AM
RoostKing's Avatar
RoostMonkey,
I would suspect the cap. If the impellor is turning, water/coolant is flowing. Without adequate pressure, created by the cap, it will not make the rounds.
RoostKing...
IMLN
09-28-2015 03:32 PM
Quadzilla Heritage
09-25-2015 01:39 PM
BigCam
09-16-2015 01:53 AM
alzgarvin
09-11-2015 08:53 AM
lancemll88
09-05-2015 03:16 AM
Quick Reply: LT500 cooling probs
