Left front wheel pushed backwards
Was this on your Eiger? ouuuuuuuch! Dont take it to the dealer and don't use a come a long. Take it to a local weld and fab shop. Here in the pacific nw most the shops are use to fabing and fix'n logging equipment Which can be tricky. Ask around and find one in your area . If they can' fix it then go on ebay but they will be able to most likely. Unless you bent a tie rod., then you can fix that, describe which way the tire is pointing.
Yeah what stainless said and the condition of your front wheel would be the camber being negative and not the tierod which would be the toe but if you bent it that bad you could have bent the tie rods and the frame . Also remeber the more metal gets bent the weaker it gets. good luck
UPLou
06-07-2015 09:42 AM
