Biggest tire size for 87 LT-4WD
Old 06-22-2007, 01:24 AM
hubba's Avatar
Default Biggest tire size for 87 LT-4WD
Hello
Wait is the biggest tires i can put on a 87 suzuki LT-4WD? Factory tire size is front 22x8.00-10 & back is 24x11.00-10. I wed like the same size on the front & back so it will look the same. Will this work?
Thanks
HUBBA
Old 07-08-2007, 12:52 AM
suzuki/lt80's Avatar
i think as long as your rims are the same so it lines-up
Old 07-08-2007, 10:56 AM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
<div class="FTQUOTE"><begin quote>Originally posted by: hubba
Thanks
HUBBA</end quote></div>
In a word - No. You can go to a larger tire size but the difference in circumfrence of the front and rear tires must remain in proportion to the stock size. That style LT adjusts the gearing between rear and front drive so that even with the smaller tires up front the axle speed is adjusted so that both front and rear are traveling at the same speed. Try putting four equal sets of wheels/tires on it and the front tires will try to pull away from the back whenever you are in 4wd.
That said, I know of at least one guy who is running equal size tires on his KQ300. Since most of the time he is in 2wd and much of the trails he rides on are sandy type soil, the 4wd crabbing is not very noticable. Different stroy if you spend a lot of 4wd time on rock or hardpack surfaces.
Bratman2
08-06-2022 01:42 AM
Hankey Pankey
05-01-2018 01:33 PM
Hankey Pankey
08-17-2015 05:01 PM
2007 Grizzley 450
08-13-2015 06:33 PM
rcappie4
07-18-2015 07:51 AM
Quick Reply: Biggest tire size for 87 LT-4WD
