convert shaft to chain
Dont know if a the quad you are talking about will work like this.
Many years ago I took a GS850 Suzuki motor and put on a go-cart.
So I needed to convert a shaft to a chain. It was really easy.
Suzuki used the same countershaft on their shaft and chain models.
The cases was all that was different. I took the gears out where the driveshaft bolts to and the gears on the end of the countershaft. Then took a dremel and cut the cases off and bought a sprocket for a GS750 and then I had a chain drive engine. Take a good look, your problem might have the same solution.
changing it to chain drive is fairly easy. take the cover off Around the shaft Output on the Engine. If the output shaft comes out of the side of the engine find a sprocket to fit it. You may have to mive the engine left or right to line it up with the swingarm. All shaft drive engines use the same case as a chain drive then a 90° gear box is attached. I've done this conversion several times over the years.
#15
#16
#17
#18
#19
#20
Don't be the problem, be the solution..
Telling someone that something isn't possible, when in fact ANYTHING is possible breeds no hope, in turn creates a situation where one will not challenge themselves.
I'm not familiar with your experience in fabrication, but mine is extensive, encompassing multiple industries over 40 years...if given the resources, technical data, and ability to work thru any and all obstacles, THEN Anything is possible.
. My peers like to say that I break steel and bend concrete...off course, would seem impossible to most until you have witnessed it. But before it can happen, you gotta Invision it, and work the problem.
mrtidy
02-03-2016 05:00 PM
Chasso
2) Chassis problems..
09-19-2015 03:06 AM
