1988 Suzuki LT-4WD No Spark!!!!!
#121
Jackie
#122
[quote=AdirondackGal;2852003]I just went out to the garage and retested. I get OL @ the connector closest to the magneto/pickup coil
I hooked up the probes to the blk/yellow & green/white at the CDI.
* You are measuring on the harness side not the CDI side right? Cause there is another Black/yellow on the CDI side.
I don't understand how the coil could be open and still produce 4 volts???
Are you taking your ohm reading from the magneto side???
Attach your leads to the b/y g/w on the harness side of the CDI plug. With key off measure ohms. Then switch to volts and start engine.
What do you get?
What do you get?
#123
#124
[QUOTE=Kenm;2852101]
Pleeeeeeze.... explain the "harness side" to me. (I just want to make sure we are both talking about the same thing. ) Then, armed with that information, I am going back out to do the tests again. Now, everything is to be connected for these tests, right? Nothing unhooked?
Thanks Ken!
Jackie
What do you get?
What do you get?
Thanks Ken!
Jackie
#125
[quote=AdirondackGal;2852115]
Thanks Ken!
Jackie
At the CDI connector, one side goes to the CDI, one goes somewhere else(harness).
Just do this test, yes everything connected:
Attach your leads to the Black/yellow and Green/white on the HARNESS side of the CDI plug. With key off measure ohms. Then switch to volts and start (or crank) engine.
I suggested earlier that you could put a lead in each side of the connector, this was to prevent a possible short. You can do this but you must be on the right colored wires ON THE HARNESS SIDE because they change colors at that connector.
Thanks Ken!
Jackie
#126
[QUOTE=Kenm;2852122]
Okay... the test results are the same:
key off: OL. Ohms
cranking: 4.29 AC Volts
I did the tests at the CDI harness side, and also at the first connector after the Magneto/pickup coil. Both tests came out the same.
What does this mean?????
key off: OL. Ohms
#127
[quote=AdirondackGal;2852134]
Does your bike start now?
Are these the same wires that you read 14 volts on earlier?
#128
[QUOTE=Kenm;2852135]
No, the bike won't fire at all. It is turning over as normal, but no spark.
Yes, these are the same wires I tested this morning. They had 14 volts and the bike started.
#129
[quote=AdirondackGal;2852139]
And when you did this test:
"and also at the first connector after the Magneto/pickup coil"
you were on the side of the connector that entered the magneto?
#130
