230 Mystery
230 Mystery
I have a 1986 suzuki 230 qaudrunner. I have had it 2 years and all of a sudden when I first start it it spits & sputters for maybe 2 minutes & then it runs great. Now it takes about 5 to 10 minutes to run good.At times i start it and it runs great. I sent it to a shop and it did the same thing the gay said he checked compretion & everything else he could but nothing.
I hope someone has had something simular to this and found the problem.To this day it has not fouled a plug. When it runs good it will outrun my 250 same year. If you have anything to suggest thanks.
The intake valve being out of adjustment is definitely a cause of cold starting and running problems. Dirt wears away at the valve face and eventually the .001-.003 lash setting goes to zero and the valve never closes. Your carb may need a good cleaning too. Backfiring is lean, so maybe your jets are plugged or your air filter came loose.
CoffeeRoasterDS650
09-30-2005 08:14 AM
