L400 problems
L400 problems
so i have an 03 L400 and it ran awsome over the summer. once fall and winter came around ive had problems starting it. It wont start with the starter but it turns over just fine. the only way i can get it started is if someone pull starts me and i hold it wide open. it seems like its flooding and its loaded up when it does fire and starts. I took the carb apart and cleaned it and noticed it has 5 different jets... not sure what ones i should change if thats even the problem. The valves sound loose and theres alot of ticking comming from that area while idling but i had the valve cover off over the summer and they wernt really loose just on the loose side of specs. does anybody know what i should do?
