1987 LT250R Rear Shock Question..
Old 07-15-2010, 09:49 AM
4thGenLude's Avatar
Question 1987 LT250R Rear Shock Question..
Hey guys.. been reading here for quite a while.. have found a lot of valuable information but none concerning the problem I'm having right now..
I'm in the midst of rebuilding an 87 Lt250R and have come to notice a problem with the rear shock since bolting it in.
The quad is on all fours and the rear shock is EXTREMELY stiff.
I should add that it doesn't appear to be the stock shock..
It is set up and looks exactly like this.. only red:
-Now the fitting coming out of the bottom of the shock is off to the side as opposed to out the back like the one in the picture.
-The fitting on the canister is located on the side as well..
-Since the fitting on the bottom of the shock itself is off to the side.. the line looks like it COULD be kinked.. not terribly.. but I'd say at a 90 degree bend.. I'm not sure how finicky these things are
-I pressed the nipple at the top of the canister and nothing happened.. no pressure.
When I say stiff.. I mean like it moves maybe half an inch when i press down on the back of the quad.
Any suggestions/advice would be greatly appreciated!!!
Old 07-15-2010, 11:07 AM
4thGenLude's Avatar
I should also add:
-On the top of the shock there is a dial that says "UP" with an arrow pointing clockwise. Values of 1 - 4 or 5 I believe.
-On the bottom of the canister there is another dial. It doesn't click or make any sound. It doesn't max out in either direction. (keeps spinning)
Old 07-18-2010, 01:12 PM
4thGenLude's Avatar
No love
Old 07-18-2010, 01:34 PM
NewportHillClimber's Avatar
so the one in the pic isnt the one in question? do you have a picture of yours?
Old 12-11-2011, 08:20 PM
atvboy4ever's Avatar
mybe it has a diff spring in it
Old 01-22-2012, 06:19 PM
bricetingle's Avatar
Ok im about 100lbs and i love jumping and going fast i would like my shocks on my 02 ltz250 to be as soft as possible and as low i am lower my front shocks what else should i do??????
mywifesquad
8
09-21-2015 08:20 AM
Steeldon
09-08-2015 10:51 AM
black_thunder
09-07-2015 01:24 AM
OutRacing
Technical and How-To Articles
09-03-2015 07:49 AM
snowolson
08-31-2015 03:51 PM
Quick Reply: 1987 LT250R Rear Shock Question..
