cold start?
cold start?
my 07 ltz400 quadsport won't start when cold. i can roll start it and everything runs great and the idle is good no back firing or anything but i can not get it to start when i first go to ride it i have to roll start it and let it warm up. after that and i cut it off it will start but takes a few seconds and doesn't start like it use too. any suggestions?
Make sure battery connections are tight and corrosion free, load test the battery at a cycle shop. If battery tests OK, clean starter wiring and connections, as well as solenoid.
The problem is one or more of five things, weak battery, corroded cables, faulty solenoid, faulty starter, bad starter switch. Always use a Battery Tender to keep the battery at full power.
Big600twin
06-10-2015 03:01 PM
