2007 450 King Quad Died : (
Old 10-05-2010, 02:26 PM
Rock Doc's Avatar
Angry 2007 450 King Quad Died : (
Hi there,
Having a very bad day today. I was out doing yard work with my quad today when it just suddenly died.
I can cycle the key and get the dash to power up eventually, however as soon as I touch a brake, power the winch, or hit the starter everything dies including the dash. The neutral light will turn on momentarily when the ignition is 1st turned off. Then I cycle the key on and off and eventually I can get power to the dash again. The fuel pump does not trip on though (it actually did the 1st time I did manage to get power to the dash, but I heard a snapping noise when I hit the starter and it died).
At the bottom of the dash it does say "chec", but I can't seem to get the ECE to trip into diagonstic mode using a paperclip. I can put power to the winch by bypassing the relay under the seat even with the ignition turned off.
Any thoughts. The relays are pretty pricey so any advise on how to diagnose the problem would be greatly appreciated!!! I will say that the bike got worked in reverse pretty hard yesterday as I was trying to back my enclosed traielr with 2 sleds into place. The power limiter kept kicking in - wonder if this might have caused a problem.
I suppose one good thing is that it happened in my yard and not on the trail.
Old 10-05-2010, 05:11 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
It's a longshot but my buddy's 700 did that. Dash would come on but as soon as he hit the start the dash would die. Took it into the shop and found that it was the positive cable from the battery to the solenoid. Didn't even look bad. Just a start for you.
Old 10-05-2010, 05:46 PM
Rock Doc's Avatar
Thanks for the tip. I cleaned it up and the dash is staying on now so hopefully that is the problem.
Sjrpp
05-02-2023 03:59 PM
Sjrpp
06-02-2019 07:25 AM
DOC HOLIDAY
07-09-2015 01:09 PM
Sjrpp
07-05-2015 09:04 PM
D-Hagz
07-04-2015 02:19 AM
Quick Reply: 2007 450 King Quad Died : (
