Start rope replacement
Hi. Any one have a site or instructions on how to change the starting rope on a LT-A50 quad.
I replace the old one because the nok broke, and try to put everything back the way it was, but i pull it once, twice, and the the rope never retract.
Please help my kid is about to strangulate me.
If it is anything like my suzuki, you need to take the pull start assembly off and remove the pull rope from the assembly. You then need to rotate the spool in the direction that would turn the engine over which will give you resistance against the spring inside. You should rotate it about 5 or 6 times until it is nice and wound up and you can barely hold it by hand. Feed the rope throught the hole in the assembly and through the crank and either tie it in a not or whatever you need to do to hold the rope. You can either slowly release the assembly and let it wind back or move your fingers really quick and let it snap back. This should wind it up for you. Once your tie your not and it is good and tight, hold the assembly and pull it in and out a few times and make sure it works right. You should be good to go.
Something wrong!!
Hi and thanks for the help. I took the mechanism apart, install the new rope, assemble everything back as i recall it was before. Pull the rope like 5 times and it get stuck out.
Maybe the ratchet or i dont know. Will keep trying, would be easier to take it to the mechanic, but i really wanna learn how to do this "simple" fix. You never know when you may need that knowledge.
Something wrong!!
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
