Eiger 400 carb isssue
Jim:
Sounds to me like the fuel mixture is too lean. When air flow is restricted, the ratio of fuel to air is higher, giving you more of a "correct" mix in order to run.
Thinking out loud, you probably have a clogged jet in the carb. Probably worth the time to pull the carb, clean it with a good carb cleaner (I use Super Tech from Wal-Mart---cheap and very effective) and blow dry all ports, passages, and jets with compressed air. Don't use wire or drill bits to clean the passages--it can cause damage and a new carb is about $400.
May want to spring for a rebuild kit--about $35, can get on EvilBay somewhat cheaper.
My suggestions--I'm sure some other guys will chime in as well.
Good luck--keep us posted on progress.
Tom
Tom
sounds like it is time to pull the carb and clean the jets, ports, and passageways. Remove the idle mixture screw cover at the bottom of the carb, carefully turn the screw clockwise until it bottoms out, the back the screw out 2 1/2 turns--you'll slightly lose fuel economy, but gain much better throttle response and quicker warm-ups.
