problem with cam chain tension
Old 11-01-2010, 02:40 PM
cbaumy's Avatar
Default problem with cam chain tension
I have a Suzuki lt250ef that I have just got running from being sat up for a long time. While I was test riding it, it jumped timing on me a quarter turn, which luckily it wasnt while the valves were down!. I reset the timing and noticed I have a little to much slack on the cam chain. My cam chain tension is all the way in, which is a self adjusting type of tensioner. When I install the tensioner it is leaving to much slack in the chain. When I push in with my finger about a 1/8 to a 1/4 inch more than the tensior it is fine with no slack on the sprocket. Before I throw any more money at this quad, I would like to know if it would be better to change first, the cam chain slide, tensioner, or chain. Which do you think would fail first. this is my first quad so any help would be appreciated.
The following users liked this post:
Daniel Lowery (02-24-2021)
Old 11-03-2010, 10:53 PM
JustRandy's Avatar
You need a new chain. I have welded a nut on the end of the tensioner to push in that extra 1/4 inch and have it last like that for years. A guy at a machine shop might weld it for free since it takes 2 seconds. I don't know if I would trust a glue like jb weld.
Sjrpp
05-02-2023 03:59 PM
Firefighter400
10-08-2022 06:38 PM
Sjrpp
11-15-2019 09:59 PM
Sjrpp
06-02-2019 07:25 AM
95wolv
07-17-2015 08:13 PM
Quick Reply: problem with cam chain tension
