lt250r Chassis Oil Seals / Fittings?
Old 11-15-2010, 01:44 PM
PinkFloydEffect's Avatar
Lightbulb lt250r Chassis Oil Seals / Fittings?
Where do these grease fittings belong? They were in the spare parts but I can't even find them on my quad anywhere?
Then I have my rear axle carrier which spits grease where the brake disc is suppose to be, bad or no "dust seal" ??
Old 11-19-2010, 03:49 PM
willard13's Avatar
Default rear brake
your rear brake rotor goes on the right hand side of the quad, when you are looking at it from the back. you will need three bolts to hold that in place. i can see the bracket in the pic. also those grease fittings that are in the pic, do not belong to this quad. when putting this together, make sure you use some locktight, {medium}. any other question let me know i just redone one of these last year?
Old 11-19-2010, 06:19 PM
Yeah I know all about the brake disc lol, good to know those fittings don't belong to my machine though. Grease doesn't stay in my axle carrier, so I'm going to have to take it apart and check the dust/oil seals.
Old 11-21-2010, 06:36 PM
willard13's Avatar
If you going check the seals in the axle, I would pull the axle and replace the carrier bears and seals.
EIF
04-20-2017 07:15 PM
wrencher82
09-28-2015 10:02 PM
Ahtatu
09-28-2015 12:14 PM
tysonbully
09-28-2015 02:30 AM
Levi Enstad
09-26-2015 08:00 AM
Quick Reply: lt250r Chassis Oil Seals / Fittings?
