Suzuki Eiger Flywheel Removal
Old 01-14-2011, 08:33 PM
steve931's Avatar
Question Suzuki Eiger Flywheel Removal
I pulled the side cover and removed all fastners to the magnetic flywheel. I tried a two prong puller w/no luck. Is the flywheel threaded or on a taper shaft. Any help would be greatly appreciated. Thank,s steve931
Old 01-17-2011, 03:25 PM
ba300's Avatar
Orginal Trespassers
I just saw this thread
Did you get it off???
Old 01-18-2011, 06:51 AM
papa hogg scoot's Avatar
Need an puller thats threads to flywheel, the crank is tapered were the flywheel seats, yes new flwheel should come with complete assy. ready to mount and used....
Old 01-18-2011, 08:48 AM
steve931's Avatar
Default rotor removeal
Yes, It was a taper lock. I had to heat rotor and I had a good set of pulley pullers it came off w/a/Bang!!!!!!!!!! Thank,s
Old 02-14-2011, 08:54 AM
PAPABARA's Avatar
Hi i have a 2003 eiger that the magnets have let go. Rickstator.com has a puller for about 40 dollars. I understand that the magnets glue releaseing is becomming a big problem on the eiger engines. I have gotten in tuch with one of the larger apoxie makers. They told me that using a glue or apoxie to stick a magnet to steel is a very bad design. The glue is forced out by the natural pull of the magnet and has no choise but to turn loose over time. They are looking at process that will work and they are going to call me back. But i am going to need some broken flywheels and magnets to work with. If any of you would like to help find a cure let me know.
merryman
01-19-2016 04:29 AM
Hankey Pankey
08-17-2015 05:01 PM
kdg723
07-25-2015 01:20 PM
baysport
07-23-2015 11:37 AM
ghost civic
07-15-2015 10:48 PM
Quick Reply: Suzuki Eiger Flywheel Removal
