z400 torque specs
Torque Specifications
Engine and Chassis Torque Specifications (Go to the lower half of the list for 2005 thru 2007)
DVX400 2003-2004
KFX400 2003-2004
LT-Z400K4 2004
ENGINE TORQUE SPECIFICATIONS N-m / ft-lb
Engine oil drain plug crankcase 21nm 15.0ft-lb
Engine oil drain plug oil tank 12nm 8.5ft-lb
Engine oil level screw 5.5nm 4.0ft-lb
Crankcase bolt outer 11nm 8.0ft-lb
Neutral switch bolt 6.5nm 4.7ft-lb
Oil hose banjo bolt on crankcases 23nm 16.5ft-lb
Starter motor wire lead nut 6nm 4.5ft-lb
Starter motor ground wire bolt 10nm 7.0ft-lb
TDC plug 23nm 16.5ft-lb
Engine mounting nut and bolt 66nm 47.5ft-lb
Engine mounting bracket bolt 26nm 19.0ft-lb
Exhaust manifold nut 23nm 16.5ft-lb
Muffler connecting bolt 23nm 16.5ft-lb
Muffler mount bolts 23nm 16.5ft-lb
Counter shaft sprocket bolt 10nm 7.0ft-lb
Fuel valve mounting bolt 4.6nm 3.3ft-lb
Valve cover bolt 14nm 10.0ft-lb
Cylinder head bolt, 10 mm 46nm 33.5ft-lb
Cylinder head bolt, 6 mm 10nm 7.0ft-lb
Cylinder head side bolt 14nm 10.0ft-lb
Cylinder nut 10nm 7.0ft-lb
Camshaft journal holder bolts 10nm 7.0ft-lb
Balancer driven gear nut 50nm 36.0ft-lb
Primary drive gear nut 140nm 101.5ft-lb
Flywheel nut 120nm 87.0ft-lb
Clutch hub nut 70nm 50.5ft-lb
Gearshift arm stopper bolt 19nm 13.5ft-lb
Gearshift cam driven gear bolt 24nm 17.5ft-lb
Cam chain tension adjuster bolt 10nm 7.0ft-lb
Cam chain tensioner mounting bolt 10nm 7.0ft-lb
Cam chain tension spring holder bolt 30nm 21.5ft-lb
Cooling fan thermo switch 20nm 14.5ft-lb
Engine coolant temperature switch 13nm 9.5ft-lb
CHASSIS TORQUE SPECIFICATIONS N-m / ft-lb
Cushion rod nut 78nm 56.5ft-lb
Cushion lever nut 78nm 56.5ft-lb
Rear shock absorber mounting nut lower 55nm 40.0ft-lb
Rear shock absorber mounting nut upper 60nm 43.5ft-lb
Rear swing arm pivot nut 84nm 61.0ft-lb
Rear axle housing bolt, 12 mm 100nm 72.5ft-lb
Rear axle housing bolt, 10 mm 73nm 53.0ft-lb
Rear axle nut 180nm 130.0ft-lb
Rear sprocket mounting bolt 54nm 39.0ft-lb
Seat rail mounting bolts, 10 mm 55nm 40.0ft-lb
Seat rail mounting bolts, 8 mm 26nm 19.0ft-lb
Foot rest mounting bolts 55nm 40.0ft-lb
Parking brake adjuster lock nut 18nm 13.0ft-lb
Parking brake bolt 28nm 20.5ft-lb
Rear brake caliper holder slide pin 23nm 16.5ft-lb
Rear brake caliper holder pin 18nm 13.0ft-lb
Rear brake pad mounting pin 18nm 13.0ft-lb
Rear brake pedal nut 11nm 8.0ft-lb
Rear brake master cylinder rod locknut 18nm 13.0ft-lbft-lb
Front brake pad mounting pin 18nm 13.0ft-lb
Front brake pipe nut 16nm 11.5ft-lb
Front brake caliper holder slide pin 23nm 16.5ft-lb
Front brake caliper holder pin 18nm 13.0ft-lb
Brake master cylinder mounting bolt rear 10nm 7.0ft-lb
Brake master cylinder mounting bolt front 10nm 7.0ft-lb
Brake caliper mounting bolt rear 26nm 19.0ft-lb
Brake caliper mounting bolt front 26nm 19.0ft-lb
Brake bleeder (air ) valve 7.5nm 5.5ft-lb
Brake disc bolt rear 23nm 16.5ft-lb
Brake disc bolt front 23nm 16.5ft-lb
Brake hose banjo bolt 23nm 16.5ft-lb
Wheel lug nuts rear 50nm 36.0ft-lb
Wheel lug nuts front 50nm 36.0ft-lb
Wheel hub nut rear 100nm 72.5ft-lb
Wheel hub nut front 65nm 47.0ft-lb
a-arm pivot nut 65nm 47.0ft-lb
Front shock absorber mounting nut upper 60nm 43.5ft-lb
Front shock absorber mounting nut lower 60nm 43.5ft-lb
Tie rod lock nut on shaft 29nm 21.0ft-lb
Tie rod lock nut on steering knuckle 60nm 43.5ft-lb
Steering knuckle nut upper and lower 43nm 31.0ft-lb
Steering shaft nut 49nm 35.5ft-lb
Steering shaft holder bolt 23nm 16.5ft-lb
Handlebar clamp bolt 23nm 16.5ft-lb
DVX400 2005-2006
KFX400 2005-2007
LT-Z400K5 - K7 2005-2007
Generator rotor nut 120nm 87.0ft-lb
CHASSIS TORQUE SPECIFICATION N-m / ft-lb
Rear shock absorber mounting nut lower 60nm 43.5ft-lb
Rear axle nut 240nm 173.5ft-lb
Rear sprocket mounting bolt 60nm 43.5ft-lb
Seat rail mounting bolts, 8 mm 55nm 40.0ft-lb
Brake bleeder (air) valve 7.5nm 5.5ft-lb
Wheel lug nuts rear 60nm 43.5ft-lb
Wheel lug nuts front 60nm 43.5ft-lb
Steering knuckle nut upper and lower 29nm 21.0ft-lb
Handlebar clamp bolt 26nm 19ft-lb
DVX400 2003-2004
KFX400 2003-2004
LT-Z400K4 2004
DVX400 2005-2006
KFX400 2005-2007
1ArmBandit
55
10-14-2015 09:03 PM
