Valve Lash
Valve Lash
I know that the lash settings for the 230 are as follows:
.001-.003 - Intake
.003-.005 - Exhaust
This is probably a rookie question, but is it better to be .003 than .001 for the Intake? Is .003 better than .005 for the Exhaust. Should I shoot for the smallest gap, the largest aloud, or inbetween.
.001-.003 - Intake
.003-.005 - Exhaust
.001-.003 - Intake
.003-.005 - Exhaust
.001-.003 - Intake
.003-.005 - Exhaust
are you sure that you adjusted the right valve at .004? the exhaust valve should be easy to get to. its in front on the engine above the header pipe and you have to remove your fuel tank to easily access your intake valve.
take the spark plug out and use a flashlight and check to see if the piston is all the way up. it makes rolling the engine over easier and you will be able to tell if the piston is at TDC.
