LT 80 problems
Old 02-21-2011, 10:12 AM
Jfolse's Avatar
Default LT 80 problems
I have a 2000 LT 80 Suzuki that keeps dripping gas out of the exhaust where it connects to the bike. I don't knoiw alot about these machines, but I did recently take off the exhaust to remove the restrictor plate and when I put it back on I noticed the leak. I'm also in the process of installing a new petcock to hopefully solve the flooding problem. Will the new petcock solve the exhaust leaking problem?
Old 02-22-2011, 08:18 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
If the leaking is caused by the motor being filled with fuel, yes a new petcock "should" stop it.
I personally think this is common and just the way 2 strokes are.
You could try a new exhaust gasket.
I've seen new petcocks leak. Get a on/off valve (3 bucks or so) at advance auto or a lawn mower shop.
Old 02-22-2011, 08:39 AM
Jfolse's Avatar
Default Re: LT80
Thanks for the response. I was just concerned because the muffler wasn't leaking until I took it off to remove the restrictor plate. I installed the new petcock yesterday so I'll test run it this evening to see if the leak is stopped. That little quad flies now without the restrictor on the muffler!!!
Old 02-28-2011, 02:47 PM
jarretts dad's Avatar
can anybody help me out ??? i got a 2001 lt80 new piston/rings carb rebilt and a new petcock on fuel tank .. will not start. or a temp to run .. new plug has spark...
what am i missing ??????????
Old 02-28-2011, 05:07 PM
LT80's Avatar
LT80 Expert
If you start your own thread maybe more will see and respond.
Anyways, If it has not started since rebuild, try bringing up the compression with a few drops of oil in the plug hole.
Is the plug wet with fuel?
Sometimes you need to hand choke them with 2 fingers in front of the carb (never figured out why).
Guess we'll go from there.
Old 10-24-2011, 01:02 PM
JOEYG's Avatar
I went to take quad out for the kids and it wont start My Cylinder was full of fuel I am going to order a new Petcock for it. Do you think that is the problem?
Where Are the restrictor plates located and how do you know if they are instaled or not?
What do you do for maint on it is there Any oil in the motor?
Thanks
greg74
09-10-2019 03:03 PM
ogio117
Polaris Side by Sides
04-29-2019 03:14 PM
ScopeZ_
07-28-2015 01:44 AM
Ty64
Technical and How-To Articles
07-25-2015 02:02 PM
hondarider1234
07-21-2015 11:53 PM
Quick Reply: LT 80 problems
