lt80 trouble
Old 03-01-2011, 08:06 AM
jarretts dad's Avatar
Question lt80 trouble
hey guy's
i got an 01 lt80 i just rebuilt the carb. with carbon reeds. put new fuel petcock on last week when i did the carb. fmf pipe, put new piston and ring's in it last year. bike ran good for a month then but stopped running been sitting for a year so i did the carb. and new plug. i have 20lbs of compression when turning motor over .. i dont think the plug is getting wet with fuel . we have put gas in head put plug back in and nothing...
any good idea's where to go from here??????????
Old 03-01-2011, 08:22 AM
LT80's Avatar
LT80 Expert
Tell me it's 120 not 20 for compression.
Some times you have to hand choke them.
So it ran for a month after the rebuild then just quit?
Old 03-01-2011, 08:27 AM
Question
yes sir . it ran like a champ then one day it just stopped.
i should have 12o lbs of compression in it ??? i will have to go back and check it again.. to make sure on that.. i did get it to fire one time with starting fluid once that burned off it was over.. nothing sent's then... could i have broken a ring????
Old 03-01-2011, 11:00 AM
LT80's Avatar
LT80 Expert
If your comp reading is close to correct, I think you fried a piston.
Old 03-01-2011, 11:14 AM
Question
so i need to pull the head . and check the piston and ring's then ..
thank you
Old 03-01-2011, 11:17 AM
i did have fuel in the crank case. when we had the carb off we dumped it all out i do think.
Old 03-02-2011, 02:01 PM
jvav619's Avatar
where did you find carbon fiber reeds for an lt80? i might be interested in picking some up
LT80 is right about the compression though, it usually takes around 90psi to fire a motor, you may have a hole in the top of the piston if your compression is only 20. gl
Old 03-02-2011, 02:05 PM
Question
mid west mini's i think it was .... like 20-30 buck's got them last year..
Old 03-02-2011, 02:11 PM
Thumbs up
james lucky
TDR Reed Carbon Fiber LT80/TriZ
Quantity in Basket: none
Code: 28AC
Price: $24.00
Shipping Weight: 0.20 pounds
see if this will help you out ..
Old 03-02-2011, 02:12 PM
jvav619's Avatar
are they black carbon fiber or the white composite ones made by boysen?
Quick Reply: lt80 trouble
