86 quad sport starting and running issues
I just picked this classic up off a kid who was tired of dealing with it. The problem is very hard starting, he thought it was the valves. got it home and cleaned out the carb, replaced plug, figured i would start the the easy stuff first. seemed like it wanted to fire as long as no fuel was being applied. finally turned over but would not idle. Got started again was getting really tired of kicking,it fired up, giving it gas was missing like crazy not winding up like it should, turned light switch on to see if headlight worked bike started backfiring and really missing till it stalled with me using the gas. Would the cdi box be the cause of the problem or is it something electrical? any help would be appreciated, thanks in advance!!
thanks got all the plastics and gas tank off ran out of time yesterday, will check wires either today or tomorrow. did find where key was someone installed a toggle switch that the wires were broke on but that dident seem to matter after the fix. how much you lookin for the cdi box and carb Trailrider230s?
CDI= $60
Carb=$25
bout $85 shipped free to you. and also i will include the voltage regulator with it and the carb will have the throttle cable and slide with it also. i prefer to sell the electronic pieces as a set because i know they all work together.
