1989 lt250s carb issue
Hello everyone,
Yesterday I tried to adjust the air/fuel mixture adjustment screw on the carb to help with the idle and red hot pipe issue. I was told if you screw this all the way in or all the way out the engine will bog out. I did it both ways and the engine was not affected, it stayed the same. I pulled the screw all the way out and found a spring and also a broken brass washer and broken o ring (I ordered them new). Could this be my problem, and also when adjusting the screw should it bog down? What is the correct setting for this?
Thanks for the help.
