Sand in oil reservoir--LT-Z90
take the drain plug out and drain the oil then use some clean used motor oil and run it through it to flush a few time to clean the bottom out then after it looks clean put new oil in and it should be fine the only worry is the bearings as long as sand didnt get in them you fine and when its running it dont make nose your all good
07-24-2015 11:57 AM
