2007 king quad 700
Old 04-09-2011, 12:13 PM
dwheath1's Avatar
Default 2007 king quad 700
Just bought used king quad. To check oil, manual says "oil filler cap threads are not run in but touching the filler hole upper edge". I read this as holding the filler cap against the threads, but not threading in. Am I correct, or does the cap need to be fully threaded in to check level?
Old 04-09-2011, 09:18 PM
ROWDY33's Avatar
You are correct. The "dip stick" just sits on top of the threads. I'm also sure that you let the engine run then you let it sit for 2-3 minutes then inspect it.
Sjrpp
05-02-2023 03:59 PM
Sjrpp
06-02-2019 07:25 AM
DOC HOLIDAY
07-09-2015 01:09 PM
Sjrpp
07-05-2015 09:04 PM
D-Hagz
07-04-2015 02:19 AM
Quick Reply: 2007 king quad 700
